When I scan the registry I find dozens of missing MUI reference. Can I safely delete them after making a registry back-up? Thanks.
You should always remove at your own discretion, because we don't know how your system is setup, but generally if you take a backup you should be able to remove (and if there's a problem; restore from the backup.)
