Registry Mechanic won't start
I have a registered version of Registry Mechanic but the program runs one time and I am unable
to restart it. After a reinstall the Help/About menu shows that I am the licensed user. I
don't see a 'Register' button.
Please advise,
Jack Gerst
I am assuming you have posted here in error and need the Registry Mechanic forums?
http://www.pctools.com/forum/forumdisplay.php?f=9
Perhaps he believes CCleaner to be at fault.
Well I know older versions of RM needed Internet Explorer installed, and if removing Internet Explorer to downgrade back to an older version ("8->6") it would even state removing it may cause RM to no longer function. So maybe the problem with it not starting has to do with a problem in IE.
