CCleaner worked fine until now. CCleaner will not remove these Activex Files they keep coming back. The Activex as follows: Activex/Com ComPlusMetaData.MsCorHost.2 this is repeated. The other is
Thank you for the reply. I'm not sure how to get permission. I am log on as administrator. I use FireFox. I have XP under system tools I don't see any repair permission.
I just got a report on HijackThis and the tech listed siteadvisor as an adware,
Siteadvisor is an firefox extension. I ran Spybot Search and Destroy, Ad-Adware, ZoneAlarm, Windows Denfender. None of these programs show any spyware on my computer.
As for as the Activex files , CCleaner is the only one that listed these for cleanup in the registry. I am not a pro at this please expain how I get repair permission. Thank you for your help.
Tools -repair permissions - go, these are your instructions to use in DIAL A FIX which you downloaded.
Thank you very much. Now Activex files are removed. In the addition to the Dial-a-fix I needed the Secedit.exe. It was so simple after looking back I learn something here thanks again to all that help me and was so patient with me.
