Registry issues
Hi
I got the attached list of registry issues in question. Are these safe to delete?
(The two are of the same list from both sides)
Thanks
Just make a backup when asked to and also use Erunt .
In this case ARP cache will refer to Add Remove Programs and not the arp cache of your internet connection.
Hi
Thanks
Thank you for your reply Hazelnut. Another thing, I`m unable to enlarge the thumbnails I myself put.
I`ve tried with another threads with same outcome . any ideas what is wrong?
Thanks
