When I run CC Registry, it finds more than two pages of issues. (See attch files) I click Fix Selected Issues and they all disappear. But with few exceptions, they are still there when I scan the Registry again. . Also, note the many where it says "failed." What failed? I've been told there often are a few items that repeat; this large number, and the "failed" concern me. Should I be?
Thank you
![post-57409-0-38657600-1367363742_thumb.jpg]()
![post-57409-0-28479100-1367363755_thumb.jpg]()
I first posted this in Cleaner Suggestions by mistake. When I do a registry scan, many items are listed as "failed." Also, after I click Fix Selected (all), the screen clears. But almost all the items reappear in the next scan, even if it's just minutes later. The large number of "failed," and the large number of "fixed" that reappear, concern me. Suggestions very welcome. Thank you.
![post-57409-0-17030700-1367364472_thumb.jpg]()
![post-57409-0-62198100-1367364483_thumb.jpg]()
please take some time to read my signature, it should answer your question ![:)]()
Worth checking the Microsoft Updates website (http://update.microsoft.com/) for all those failed updates listed to make certain they are indeed properly installed on your computer.
