Registry Issue
Hello,
I recently performed a clean and registry procedure. In the registry procedure I was unable to remove the following file:
"ActiveX/COM Issue LocalServer32\C:\WINDOWS\SysWOW64\Speech_OneCore\Common\SpeechRuntime.exe -ToastNotifier HKCR\CLSID\{265b1075-d22b-41eb-bc97-87568f3e6dab}"
Would someone offer advice please. Thanks
Jerryar
1 hour ago, Jerryar said:
Yes, the advice is that you should leave it alone.
It is needed by Windows, which is why Windows keeps putting it back if you remove it.
See this for more info on what it is, (and why you shouldn't be using the registry cleaner with Windows 10 unless you have a problem to fix).
See also the post by Dave CCleaner which follows that one and explains CCleaner's current policy on using the Registry Cleaner.
https://community.ccleaner.com/topic/59952-i-get-a-registry-error-on-ccleaner-on-windows-10-i-have-scanned-5-times/?tab=comments#comment-326797
