Registry Help
when i run CCleaner I get 120 reistry issues which are removed when i scan again they all reappear Ive tried several reg cleaners any ideas
Many thanks Paul :mellow:
Are you sure they are the exact same entries? Sometimes deleting entries will cause more to become invalid. Try running the issues scan 4-5 times and see if they disappear. If not then reboot after deleting them to see if they have been deleted.
Thanks for reply
Entries are the same each time even if ran 5-6 times and reboot
Finding this very odd as it never has done this before
<_<
What kind of scan are you doing? (Windows, Applications, issues)
Im doing the issues scan
<_<
<_<
I was skimming ;), sorry. I'm trying to answer to many questions at once. Without knowing the entries I dont know. Try to reinstall CCleaner.
Tried reinstall still no joy 99% of entries say more or less the same
"invalid CLSID These are often left behind after uninstalling software.
Hope that helps
:o
>Deleted<
not sure what you mean
B)
It means I put something stupid that I deleted. :lol: Try to remove the entries a a little at a time to see if you can get rid of any of them, instead of clicking fix all.
