After installing Norton Security, this registry kept staying in the result after registry scanning. It seems it is a false positive:
Missing TypeLib Reference IBackupLocationsShellFolderImpl - {00020424-0000-0000-C000-000000000046} HKCR\Interface\{F0E3A5D7-80C7-4228-90FE-61DF01C417A5}
registry.txt
This key is probably needed by Norton.
Just right-click on the entry and select ''add to exclude list'
The key is DEFINITELY related to Norton. It's listed as not connected to anything because you realllly don't want your security software making it easy to be disabled. You'll need to, as Hazelnut stated, right click the entry and add it to your excludes.
As always the best advice I can give you for registry cleaning is to read and follow the instructions in my signature
I have experienced the same issue, and I appreciate the helpful replies to this problem.
registry.txt
