Registry cleaning, it is ok to use?
I am using CCleaner many years and i always used registry cleaner to fix all issues. But i read on the internet all registry cleaners are bad and can damage system. I have never had any problem, so what is true about this? Do you use this cleaner for fix everything registry issues it finds like me? Or i should stop using this feature anymore? Do you notice any problem after using this? I have Win 7 64 bit. Thanks
This best advice I can give for registry cleaning is in my signature.
So registry cleaners should not be used. So i don't understand why its part of that good program.
Honestly, I never got it either. But, if you clean judiciously, it's perfectly safe.
You never used registry cleaning or what you think? I think there is no benefit clean registry, only risk. I didn't know that in past. My mistake. But PC run just fine even cleaned by CCleaner.
Basically use it at your own risk. I like you have used ccleaner's registry cleaner for years without running into any issues but it's best to check what you are deleting and do backups, that way if anything does go wrong you should be okay.
Yes i do backups, but i don't know which key is safe delete and which no. Most time after windows update, CCleaner finds missing shared DLL's to NET.Framework. It is safe to delete? Any issue not apperar after delete those keys. Thanks
Sorry for the necropost, but, in my experience, registry cleaning can make the PC work slower in the future, but it won't break it.
2 hours ago, lemustagus said:
oh it can break it, it can break it big time, like won't get past booting big time
It can break the registry in Windows 10, mostly due to Windows 10 being a constantly changing moving target. Older OSes like Windows XP I've no issue using it, but I do have a large exclusion list.
