I have been running Cleaner for years but now its NOT deleting items that it states shall be deleted
This entry remains:
Shall it be deleted or stay? Can I delete it? How?
This entry remains:
See here for posts about a similar issue
https://community.ccleaner.com/topic/59965-speedruntimeexe/?tab=comments#comment-326871
Thanks for the quick answer. Have been using Registry Scan/Cleaner for years on Win7 without problems. I now understand NOT to use it for Win 10. Can I still delete Registry entries for NON Windows entries ( ie leftovers from SW installations)? Or shall I stay away totally?
2 hours ago, glimmare said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> Can I still delete Registry entries for NON Windows entries ( ie leftovers from SW installations)? Or shall I stay away totally? </p> </div>
I personally do just that on Win10, but I leave anything that points to the OS specifically in C:\Windows alone.
That should be safe enough, it's one of the things that reg cleaners are meant to be used for.
Again it's not really necessary, (but we all like a 'clean' computer).
PS. With Windows 10 those leftovers should eventually get removed anyway, either at the monthly Patch Tuesday or more likely at the bi-anual Feature (version) Updates.
Those are also the times when you'll most often see new system entries that the reg cleaner doesn't recognise, although other smaller updates can also change the registry.
It's those regular changes that make it unwise to use a reg cleaner indiscriminately with Win 10.
Thanks for the replies !!
Topic locked. This was already being discussed in another active topic located at:
https://community.ccleaner.com/topic/59965-speechruntimeexe/
