Hi there,
I've been using Registry Clean Expert along with CCleaner to keep my registry clean and safe.
In R.C.E there's is an extra scanning option for File/Path reference registry values(reference to non existing files/folders) that is unchecked by default.
It is supposed to be for advanced users only , i have 700 errors in that category , errors that CCleaner never finds.
I wonder if anyone who uses this program can tell me about this option.
Is it safe to remove them all?
I don't have time to look 700 errors ![:angry:]()
I prefer free RegSeeker:
http://www.hoverdesk.net/freeware.htm
You do not mention which operating system you use but if you use WinXP then a run with NTREGOPT after will clean up registry slack space:
http://www.larshederer.homepage.t-online.de/erunt
It up to you I think it for Expert only my PC had 5500 on fist scan still some say dont some do if you do you may kill PC so if it XP make some restore Points fist like a few of all so back up Reg with ERUNT, If it was me I get RegSeeker & Registry Fist Aid and see if it all so find it, be safe. ![:rolleyes:]()
![:rolleyes:]()
