Reference number
How do I find my products reference number if I lost my email that initialy had that info?
If you want to manage and/or cancel your subscription then there is a webpage to use: Subscription Management
If you need to look up your Cleverbridge reference then see: Customer Support Contact Page
If you can’t use those, (eg can no longer access your registered email), or for anything else account/billing related, including refunds, then you will need to contact support.
All customers MUST now use the ‘Live Chat’ support service. It is currently the only way to contact support.
To start the support process fill in this form: Contact Form.
The 'Live Chart dialogue should open automatically with a message from the AI Chatbot - if it doesn’t open itself then there is a ‘Start Chat’ button.
If the Chatbot can’t help then you will be passed to a real person.
IMPORTANT- Don’t just fill in the form and leave - If you do not engage with the chat then you will not get any reply.
