The new UI is so beautiful!! But....
Now I can't see exactly what files are found / being deleted anymore, it's sad.
You could please remove that new UI feature or adapt it so we can see detailed log again?? *-*
Thanks for the great software!
You can right click or double click each entry to expand it, and get all the details of each file deleted.
I'm assuming that's what you mean.
Hmmm!
Now it's getting interesting!
I think it's not how it was before but it's also a great update.
Maybe I need adapt myself to this...
Definitely mixed feeling amongst members on this feature.
I like to new version
Im in favor of the new results list. Its easier for me to see now what apps or folders etc are using how much.
I like it, I think, but I've noticed it doesn't handle winapp2.ini very well (if you expand an win*2.ini setion it shows you all found files )
Thats odd. I dont have that problem. When I expand one program it only shows me the files for that item.
On a side note, I was thinking instead of using a listview control to display the results why not use a treeview. Then you could expand each program/entry or have a collapse all/expand all buttons.
I like it, I think, but I've noticed it doesn't handle winapp2.ini very well (if you expand an win*2.ini setion it shows you all found files)
I get the same thing double clicking a winapp2.ini entry. A complete list of all files.
Thanks. We're looking into this.
