Recyle Bin Secure Delete
Hi,
I realize that under CCleaner's settings, it's possible to use secure delete (ie. 35 passes). I just wanted to confirm that if I enabled that, and I use CCleaner to remove data from my Recycle Bin, it will secure delete the data inside of the Recyle Bin.
Thank You.
Yea but the CIA, FBI and Interpol can examine the hard drive if you insist on doing nasty things.
