Since last updating to CC 2.35 (ccsetup235.exe) I noticed an issue with a left over context menu handler with the trash bin option to open CCleaner.
I am running Vista x64. And CCleaner using the German language.
Since the last update the former entry "?ffne CCleaner ..." has been left. It works and links to the specific function yet you cannot turn it off in the settings and if you turn it on there you'll get to entries. Notice that "..." are added to the entry, usually the context menu just says "?ffne CCleaner". The menu item left open is peculiar with that.
I already tried to reinstall older versions to try to set the old option off with them - in vain. If I select to add the handles with the trash bin on install, the install routine yet notices the existing problematic handle and turns the internal option off and does not set up a second handle. It will yet occur if you switch with the option in the programs settings. I only found this problem as the latest update worked differently and switched that second Open CCleaner item on...
Amazingly enough I could neither solve the problem with any other registry cleaning tool so far, when CCleaner is uninstalled, to catch that blank yet somewhere existing link then. Nor did I find any handle with the trash bin context menu handles. I see all the further handles in the shell settings, no traces of the ghost "?ffne CCleaner ..." handle. There is not even any obscure handle left open, nothing. You put that somewehere else, where?
Now I really puzzle how to get rid off that ghost entry. No problem to the authors of that great software I presume.
Thanks for your great software and any hints are welcome.
I already tried that, no suggesting clues there on the whereabouts of the entries. :-(
Thanks for your quick response though. Any further ideas. The texts will not be readable as it is a multilanguage app. Any ini Files known with that exceeding those posted on the board already?
if it finds the entry, right click it and choose open in regedit, this should work else just disable it in "shell menu view"
Thanks but: No, that did not work neither. It seems the handle is not stored in the registry or at least there in an obvious manner at all. Any ideas on where else a context menu of a system component of Vista x64 could be stored?
To be frank Frank, (I just had to say that, sorry), I never take anything as a given, so have you tried a complete clean uninstall of CCleaner. I ask because you only mention re-installing older versions, and not how you do it.
You can check "Save all settings to INI file" in "Options\Advanced", and copy the ccleaner.ini from CCleaners "Program Files" folder to somewhere safe, so as to retain your customizations.
Saying that, if you don't already use that method of retaining settings, you could give it a try, and CCleaner should then ignore settings stored in any other location.
The INI file could also be checked and edited if need be to see if it reflected your settings.
If you're going to try a clean install by removing CCleaner first may I recommend allowing Revo Uninstaller Free to remove it, using at least the Moderate uninstall feature in Revo, and then of course reboot the system. Hopefully that works and gets things sorted.
Thanks.
I already tried that tool, there is no clue within the registry, I scanned it thoroughly. The only clue may be if someone knows the exact code or CLS-ID CCleaner uses.
Just a thought.
Thanks, but I could not find any relevant ini-Files so far. Language is compacted into dlls - Any hints on them?
Sorry I should have posted: I tried it both ways. In the beginning I of course installed the new one over the old one, as I got into trouble. Yet so far that always worked fine. Later I deinstalled as well - no difference. I had some issues with further programs geting into trouble after using de-installing tools not precisely made for a specific program and rather refrain from using them.
I mean I can toggle the Contextmenue handles on and off with the running program. The registry seems unaffected. Where can you further hide those entries/handles? I am puzzled. Anybody who knows the source code here and give me a hint?
Once you have checked the relevant box to enable saving all settings to INI file, it is automatically created in the CCleaner "Program Files" folder ...
If you have your Windows Explorer folder settings set to "hide extensions for known file types", it will look like this with no .ini file extension ...
Something to do with the US spelling. The UK Behaviour Blocking renders fine. Well, on my pc here in the UK. Possibly our US members will see the reverse?
O.K. the above renders fine. Before I forget, I am in the UK also.
It goes wrong below - something to do with the context of the sentence it is in.
UK Behavior Blocking renders
UK "Behavior Blocking" renders
Behavior Blocking.
"Behavior Blocking"
Why is "Behavior Blocking" rendered "behavior Blocking" ?
I assure you the first instance still has an uppercase 'B' in my composed text
but in Preview it has a lower case 'b'.
Could the problem be Beta release of software ?
E.G. I am on Firefox 4.0 Beta 6;
or perhaps the forum is using a Beta release of WYSIWYG Editor - perish the thought ! !
