Recycle Bin only shows max 2Gb
Using version 1.23.160.
The analysis and post-run report incorrectly displays the size of the recycle bin as 2Gb (2048Kb) when the recycle bin contains more than this.
I believe the default setting for the bin is 2gb and will remain so unless somehow changed. Does your bin contain more than 2gb?
I can confirm this.
Doing an analysis of my Recycle Bin it reports: Emptied Recycle Bin (100 files) 2,048.0MB
In actuality there are 100 objects totalling 3.79GB
Screenshot below:
There's currently a 2GB limit on some Recycle Bin querying options I'm looking into a work around.
