Recycle bin not empty..
Hello,
I'm using the /AUTO parameter in a Windows XP scheduled task but if I run the task from the task schedulers gui, ccleaner runs in the background (no system tray icon appears) and the task is succesful. However the recycle bin isn't emptied where it should be because it is a marked setting.
If I run the same /AUTO from within the run section of Windows XP the recycle bin is being emptied alright.
I'm using the portable version 2.19.900 of ccleaner...
Can anyone explain me this behaviour and how to overcome this?
Best regards,
Victor
