Windows XP-SP3
CCleaner 2.25.1025
When running the new CCleaner for the first time, it popped a message that says the Recycle Bin on one partition is corrupt
This is a partition that contains only one single file: the page file. The file system is NTFS 3.1, and the cluser size is 64KB.
When running CHKDSK /F during reboot on this partition, it finds and fixes some errors, but when I run CCleaner again, the same error pops up.
I have no guarantee that this is caused by the new version of CCleaner, as I had some different problems on my C: drive today.
In order to help determine if this is indeed caused by the new CCleaner version, I would like to install the previous version, which gave me no problems.
- Question(s):
- can I "downgrade" CCleaner 2.25 to 2.24, without uninstalling?
- if I uninstall CCleaner 2.25, will my settings be preserved?
