Recycle Bin icon
Hi!
Since I have installed CCleaner, each time I empty the Recycle Bin, the icon disappears from the desktop, but the name of the icon stay. I have to take it out from the desktop and take it in again to see it properly.
Please, any suggestions?.
Kind regards.
Can you please post your operating system.
Also whether you used CCleaner's registry cleaner.
Welcome to the forum :)
Thank you for your answer!
My OS is Windows 7-64 bits. I did not use the registry cleaner when the problem came up. Then I used it to try to solve the problem, but nothing happened.
Thank you in advance.
Kind regards!
Can you explain a bit more what you mean when you say..
''I have to take it out from the desktop and take it in again to see it properly''
Does this help? or this?
Thank you all!!!
I'm sorry, I did not explain it very well. Here's another explanation to clarify the problem:
- When I empty the Recycle Bin, the image of the icon (just the image) disappears, but the name of the icon remains (as you can see in the file attached; "Papelera de Reciclaje=Recycle Bin").
- To see the icon right, I have to do this: go to properties --> Change desktop icons --> "uncheck" the Recycle Bin option --> Apply --> "check" again the Recycle Bin option --> Accept (similar to what Kroozer posted).
- That problem started when I installed CCleaner. I did not use the CCleaner's Registry Cleaner before.
- My OS is Windows 7-64 bits.
Thank you very much again.
I hope it'll help.
Kind regards!
Are you using the normal recycle bin icon, or a custom icon (even if one provided by a theme)? when you installed ccleaner did you select to add the context menus to the recycle bin?
Thank again for all your help!!!
The problem is solved. I uninstalled CCleaner and installed again, and now it is ok. I did it (uninstall-install) a couple of times before posting here and I also restarted the PC. But today I installed again to check if it is compatible with other applications (such as Fences), but I didn't have to do anything cause it started working properly.
By the way, answering to Nergal: I installed CCleaner selecting and not selecting "add the context menus to the recycle bin" and I used the normal provided icon and a provided theme. The problem fixed when I installed it for fourth or fifth time. I don't know why, but the problem just disappeared
Thank you for your time. I'm very grateful to you all!
Kind regards!
