Recycle bin has program folders after cleaning
CCleaner V3.14.1616 (64 bit). Windows 7 Home Premium 64-bit SP1
I love CCleaner. Used it for years. First problem. Ran cleaner same way as always, no changes to way it has run before. My recycle bin filled up with huge files (> 1 GB) - 149 of them. They are file folders, same names and sizes as the programs they represent in the /Program Files directory. The same file folder shows in the /Program Files directory.
Example: in Recycle bin - directory Filemaker, directory epson. In the /Program Files or Program Files (x86) depending on the program. /Filemaker or /epson etc.
Afraid to delete the Recycle bin. Are these duplicates? Or are they the actual program folders, so that if I delete one, the program will stop running?
Thank you for your help.
