Recycle Bin Files - Cleaning Complete Advanced Report
Every time I run a custom clean, it shows exactly 584 additional files in the Recycle Bin that never seem to go away. For example, if the Recycle Bin in empty and I run CCleaner, the Cleaning Complete Advanced Report shows 584 files were deleted from the bin. If I delete any number of files and run CCleaner, the Cleaning Complete Advanced Report will show those files plus 584.
I've tried a complete reinstall to the latest version, but still the same.
P
It sounds as if you have a corrupted recycle bin, it happens from time to time.
Here's a link to how to fix it for Windows 10, it works for Windows 7 or 8.1 as well.
https://pureinfotech.com/fix-recycle-bin-windows-10/
Also see here
https://forum.piriform.com/topic/42673-corrupted-recycle-bin-fix/
