I want to scan an external drive with the letter I:
Windows can see the drive, and there is nothing wrong with the HD. Still Recuva won't perform a scan.
If I choose to scan the drive with the letter I: and press "Start" the program takes me straight to the result page, without performing a scan. Changing to the advanced mode, there is no letter I: to choose. The only drives I can choose are A, C and D.
Why doesn't it work?
Welcome to Piriform Magnus.
I'm not sure why that is. The only external drives that I have are flash drives (F:) and it works perfectly on those.
I would have thought thats MrG would have programmed the Drive ListBox to check for all available drives.
In mine I have an (All Drives) option have you tried that one? ![;)]()
Hi! ![:)]()
Thanks for a quick answer.
Yes, I've tried "All drives" but that only scans the A, C and D drive.
The I: drive is working fine and I can access it everywhere in Windows. The only program that can't see the drive is Recuva. It is a bit frustrating because I really think that Recuva would recover some files I moved from the disc onto a HD that now has crashed ... ![:(]()
