recuva stops at 11 percent
hello, thank you for taking your time to read my problem with recuva. i am using a ide to usb kit and every time i scan with recuva i get to 11 percent and it stops, i can click cancle but it takes awhile to actually cancle. i dont know what to do i messed with some of the settings like recreate folder structor or something like that. i dont get any thing with a fast scan but deep scan works allot i actually got 266 files. at one point left it scanning for 2 hours and still at 11 percent. is their a fix to this, i am running the latest. windows 7 x64 amd fx 4170, 8 gb memory x2 ssd in raid 0.
thanks.
i just wanted to give a update to any one who comes across this problem. i use the windows check disk gui to scan for errors and it did find errors and fixed them so i did a full scan in 10 hours. thanks for the great program piri keep it free please.
Thanks for posting back and letting us know how you got on.
Glad to know all is well now for you :)
