I heard good things about Recuva so I downloaded it from the website. THe download and installation all worked as expected. But when I run Recuva either from the start menu or from the desktop icon, I get a splash screen that lasts about 2/10 of a second then it disappears and nothing else happens.
I thought something might have been wrong with the download so I uninstalled Recuva, then downloaded a fresh copy using the alternate download site, Again the download and installation all appeared to go normally, but again, when I tried to run the program all I get is the initial splash screen for a fraction of a second.
The splash screen that pops up seems to have one or two buttons at the bottom but I can't be sure because the box is only visible for a fraction of a second.
I tried disabling my antivirus program but that didn't make any difference, still all I get is the initial screen for a fraction of a second.
The computer is running Windows XP Media Center with 1.5GB RAM.
