Recuva Start
I have been through all the Recuva instructions but cannot find where to enter information for a search.
In Advanced mode (if you've used the Wizard click on the box top r/h that says switch to advanced mode) you can sort the columns on name, date, path, etc., or enter file or path search values in the File/Path box (top r/h).
I can't get Wizard to click on. Maybe it's my computer. Windows XP Professional
Can you give me the link?
If you run using the Wizard then you will have to switch to Advanced Mode. Do this by clicking the Switch to Advanced Mode box at the top r/h. If you're not using the Wizard then this doesn't apply.
