started a deep scan several hours ago and last time I checked progress showed as stage 1 of 3 (Sacnning), progress 67% with time to go of 2 hours. Two hours later and its showing 130% complete with a time to go between 11 days and 24 days. Does this mean the program is stuck or should I let it run on overnight?
I'd leave it running; make sure that your computer is not set to 'Sleep' when inactive.
If it goes to sleep then Recuva will continue the scan when the computer wakes again but you won't be able to do anything with the results and will have to scan again from scratch. (It's some limitation of Windows).
I never trust those guesses for how long is left, not from any programme or even Microsoft Updates.
That's all they are; guesses.
Too often I've seen them jump from saying "XYZ hours left" to suddenly say completed.
How big is the drive? Obviously a multi-TB drive will take longer to scan than a 500 GB drive.
10 hours ago, nukecad said:
I never trust those <u>guesses</u> for how long is left, not from any programme or even Microsoft Updates.
Hi,
Thanks for the info. I'll have to restart it in any case as my laptop decided to reboot after an unexpected update!..
FYi its an external 1TB drive I'm trying to recover. Windows acknowledges the drives existence but tells me its corrupted. Recuva indicated it had found over 40,000 files so hopefully i may be able to get the most of them back
It keeps on getting stuck at stage 1 of 3, 9%, 4 days remaining, 78486 files found on a 1TB external drive. It's been running for over 24 hours now. I've checked the power settings to make sure that nothing is disabled for power saving. Task manager shows fluctuating cpu usage for the Recuva process. I've tried rebooting. I paid for the professional version so I expect it to work. The free Piriform version always worked like a charm, so I'm surprised that the paid version is so terrible.
4 hours ago, AC Fischer said:
the free and pro are exactly the same when it comes to recovery. A scan (especially a deep scan) will take a very long time on modern huge drives that's the nature of the beast.
