Recuva Pro drive select dropdown flashes
I just installed Recuva Pro v1.52.1086, when I click on the drive select dropdown after about 2 seconds it starts to flash. This is super annoying.
In the dropdown I see most of the attached harddrives and under the disks I see
  • Recovery..... What is this?
  • Then it has a section labeled Local disk (\\.\HarddiskVolume xx) where XX is a number. How do I map these entries to the actual drives? (see the following image)
  • What are the shadow copies?
  • In Recuva I pressed the F1 key but no help is presented.
