I am experiencing the same problem and have tried Recuva on a second hard disk. Maybe this will help diagnose things.
Recuva 1.04.104 consistently crashes while scanning my C drive (system drive) but works fine while scanning D drive (another hard disk).
On C drive, Recuva progresses from 35-55%, shows a number of files identified (30 - 550) and then crashes. This happens every time with it scanning more sometimes and less other times, but never more than the 55% mark. This happens in regular and debug mode.
I run CCleaner on the C drive and do not use it on D drive.
The debug error_log reads:
[2007-08-21 15:37:16] [iNFO ] Recuva v1.04.104
[2007-08-21 15:37:16] [iNFO ] System Info: MS Windows XP SP2, IntelĀ® PentiumĀ® 4 CPU 1.80GHz, 1023MB RAM, NVIDIA GeForce FX 5200
[2007-08-21 15:37:18] [ERROR] Exception: DriveNamesEnumerator.cpp(46) : The device is not ready.
[2007-08-21 15:37:21] [iNFO ] OEM Name NTFS
[2007-08-21 15:37:21] [iNFO ] Searching for deleted files...
[2007-08-21 15:37:22] [iNFO ] Read from MFT: 154788 records total
[2007-08-21 15:37:22] [iNFO ] File record is unnamed
[2007-08-21 15:37:23] [iNFO ] File record is unnamed
[2007-08-21 15:37:24] [iNFO ] File record is unnamed
[2007-08-21 15:37:25] [iNFO ] File record is unnamed
[2007-08-21 15:37:26] [iNFO ] File record is unnamed
[2007-08-21 15:37:27] [iNFO ] File record is unnamed
[2007-08-21 15:37:28] [iNFO ] File record is unnamed
[2007-08-21 15:37:29] [iNFO ] File record is unnamed
[2007-08-21 15:37:30] [iNFO ] File record is unnamed
[2007-08-21 15:37:31] [iNFO ] File record is unnamed
[2007-08-21 15:37:32] [iNFO ] File record is unnamed
[2007-08-21 15:37:33] [iNFO ] File record is unnamed
[2007-08-21 15:37:34] [iNFO ] File record is unnamed
[2007-08-21 15:37:35] [iNFO ] File record is unnamed
[2007-08-21 15:37:36] [iNFO ] File record is unnamed
[2007-08-21 15:37:37] [iNFO ] File record is unnamed
[2007-08-21 15:37:38] [iNFO ] File record is unnamed
[2007-08-21 15:37:39] [iNFO ] File record is unnamed
[2007-08-21 15:37:40] [iNFO ] File record is unnamed
[2007-08-21 15:37:41] [iNFO ] File record is unnamed
[2007-08-21 15:37:42] [iNFO ] File record is unnamed
[2007-08-21 15:37:43] [iNFO ] File record is unnamed
