Hi!
I'm a newcomer and my technical understanding falls off rapidly when it comes to networking. I use a La Cie edmini hard drive as a back up, connected directly to the router. I have to log in to get access. I have deleted some files which I should not have done and would like to use Recuva to look for them, but it cannot see the drive vi the router. I don't seem to have any means of accessing the relevant part of the drive by connecting via USB, when recuva can see it, but can not that part where the files are.
Does anyone have any ideas? Can I Install Recuva on the drive itself and run it from there? I do appreciate that installing it may prejudice some of the deleted files.
Are there any tweaks which will allow me access to all of the drive from a USB connection? When it is connected via USB I can see part of it from the cmd prompt, but not the part that is accessed via ethernet.
All ideas welcomed.
Many thanks,
Martin
