Recovering data deleted from USB drive
I'm trying to recover deleted files from a USB memory stick which I inadvertently deleted.
At the top it sais "Select the Drive" so I selected Removable disk G. At the bottom RH corner it sais "Recover", then "Select location for recovering". So I clicked on Local Disk C: On clicking OK, up comes the note: "Do you want to restore to the same drive - this can reduce the chance of a successful recovery".
I assume the "same drive" is G, but I want to restore them to C and if I click "no" then nothing further happens.
Now I'm confused and don't want to reduce my chance of a successful recovery, so some elementary instruction would be much appreciated.
Thanks,
Stuartp77
