This program works well, but when I accidentally deleted a bunch of files (I guess I held shift when I though I held control) I ran the program thought it would also recover the folder they were in because the program showed it and I clicked the check box, but all the files where sent to the same folder even when they were organized in separate folders. everything is a mess and it will take hours to get every loose file sorted, very inconvenient unless I did something wrong.
Switch to Advanced Mode, in Options/Actions check the Restore Folder Structure box.
I have lost many of my files before due to some faults in my system. But {link removed} has helped me in getting back those deleted files. I have also come to know about RECUVA from it.
Recuva is one of the best data recovery tools of this period.
You can try both of them, you will get back the data as it was.
