Ran CC 2.08.588 and noticed that Recent Documents list wasn't erased in Open Office Writer (File>Recent Documents). I also note that OOo isn't listed as an Application (Writer, Calc, Base) on the CC Applications tab.
I'm sure that the cleaning wasn't done because of the latter - but, why isn't the OOo Suite picked up as applications?
Thanks.
The never clear for me at home with Office 2000 and Win98SE. The same goes at work with Office 2003 and WinXP SP2. Not that I'm bothered either way.
I read a topic about this problem, try a search pattern.
Sounds like you're referring to MS Office - I am talking about Open Office. My MS Office Recent Docs get cleared by CC.
The issue, I think, is why aren't the Open Office apps shown on the Applications tab of CC.
I did a search on 'Open Office' and got nothing meaningful.
Thanks. BTW, if it's relevant, WIN XP SP3.
davey
15 July 2008 23:50
4
Hi again drmsucks,
Just go to this link and down at the bottom of the first post you can download and unzip the latest winapp2.ini file.
http://forum.piriform.com/index.php?showtopic=1110
Then make a copy for yourself.Then add some entries for Open Office 2.4 probably similar to what is already there for 2.3 .
Drop that file into your CCleaner folder and try it.Once you are happy with it update your saved copy.
They will probably come out with a new version of winapp2.ini with it, if you want to wait.
Otherwise once you get your Open Office 2.4 working,then PM TwistedMetal with your suggested additions for the next winapp2.ini.
Good luck,
davey
@davey: Thanks for the reply. This issue is not a big deal for me so I'll just wait for CC to add the Open Office apps to the Applications tab. Thanks again!
