RAW Micro SD card
Hi there,
I have 2 SD cards that are now RAW. (both turned? RAW after plugging into an LG optimus F3) I've tried a ton of programs to recover the files and none of them even recognize the card being there. the computer recognizes the card but says it needs to format the card. If i click cancel it says
"the volume does not contain a recognized file system."
I really need these pics, vids and files off the cards!! I've been researching for hours now and need help!! - Jacob
See if the info contained in this thread is of any help;
http://forum.piriform.com/index.php?showtopic=40566&hl=%2Bquick+%2Bformat&do=findComment&comment=246682
Ok I tried a quick format the sd card and it says it's write protected . . . I've slid the lock on the side and it says "unable to complete format."
can you do a screen shot, with the SD card in, of the Disk Management screen from Control Panel, Administrative Tools, Computer Management.
what is your OS and SD card brands/capacity? (in case it helps)
I know it sounds dumb, but double check the locking slide switch, some have a little 'bump' you have to push past in order to lock in the fact you want it unlocked.
