Hello! Is it possible to add an ability to queue benchmarking, free space defragmentation and error check?
And another one. There are two grouboxes in the "Drive" tab - "Status" and "Properties". Both have fixed width. So if the screen resolution (and window size) is bigger than 1024x768 there is a free space on the right (see attached picture). Is there any chances to make width of "Status" groupbox changeable (depending on the window width) to cover that free space and make the file path wider?
