I did a Full Defrag on my computer. When I click File List, I get a bunch of files. Should I check them all and press Defrag Checked or leave them alone? Please tell me the pros and cons of doing that, thanks!
EDIT: I checked all the files and click Defrag Checked. I got a popup saying: "Defrag Aborted. Some files were not defragmented. This operation cannot be done."
Click on the File list tab, hit Analyse, sort the Fragments column by descending size, select the first filename then scroll down and shift+select the first filename with 10 frags, then hit Defrag.
I then repeat for the Size column, selecting all files greater than 10,000KB.
That way I do a quick defrag of all files > 10 frags and all files > 10megs. What's left behind I can live with.
Even doing that, I will sometimes get "defrag aborted", it's usually due to files that are open eg: Outlook.
If you get that a lot, a DF from Safe Mode will fix it.
Selecting all the files in the list would just be like hitting Defrag on the first tab.
