Hamish
1
Hi out of curiosity is it safe to delete everything that shows up (after making backup) or only things which I recognize?
What is the worst that could happen?
At the moment I only delete entries which relate to a program I put on myself, if it looks windows related I just leave it.
It should be pretty safe. I never experienced any problem.
And if you would get problem, you can just restore it to prior by running the .reg file which you backed up.
I always let it delete everything it finds.
Shona
3
Would cleanup delete all that is shown? What if I don't want things deleted
Each item can be disselected if you don't want to delete them.
