Hi there,
It would be awesome if on the Summary page there would be the possibility for a QR code(maybe also the ability to only select certain aspects that you need in the code).
What is the usability? Well I am in the need of a simple tool that is capable of scanning the system for some basic stuff(i.e. processor type/speed, hdd info, ram). This info needs to be put toghether in a QR code so that the user can easily scan it and store it.
If possible, it would be great to have the code generate dynamically each time a new element is (de)selected.
Thanks for reading.
