Proper Cleaning sequence
Hi,
I wonder what the proper cleaning sequence is, i.e.
1) Analyze,
2) Launch cleaning, or
Directly launch cleaning ?
I don't get the difference between these two steps.
Thank you for any instructive answer :)
Analyze doesn't remove any files, it merely scans and shows you what will be removed if you run the cleaner. If you completely trust CCleaner then there is no need to run the analyze function but it is there for you to check what will be cleaned before you remove it by running the cleaner.
You might want to have a look at the CCleaner Beginners Guide: http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
Thank you for the info, quick, short and clear !!!
