I am having troulbe installing the new adobe flash player... when i go to adobe's website and then get flash it tells me the installer has failed so i went to fillehippo and downloaded it and now im getting the message this is not the latest version of flash please go to adobe.com to get it...
the flash version i am trying to install is 9.0.64.0 RC...
I hope some of you can help...
Thanks
As far as I can see the version you mentioned is a beta version
http://www.majorgeeks.com/Adobe_Flash_Play..._AOL_d5163.html
Uninstall the old version first.
Use the Adobe uninstaller, then do a re-install with the new version.
CraigM
I'm just trying to get flash...
i also tryed downloading a earlier version from filehippo and same message..
also the link to the Adobe uninstaller you gave isent working...
The link works ok for me.
Try going to the Adobe website an entering "uninstall flash player exe" in the search box at the top.Should be the third one down.
CraigM
just tryed that program... and i keep getting the same error...
