Progress dialog box bug
If you move the main window while defragging the progress dialog box runs off in the same direction and eventually vanishes off the screen.
Also while in "File list" with size column sorted I'm also experiencing temporary hanging for 20 seconds with my CPU maxed out.
This usually happens after defragging a batch of files, or simple selecting another drive to view and clicking back in "File list" mode.
I've never experienced this problem with previous versions of Defraggler so something is definitely not right here.
Richard S.
anyone else noticed temporary lock-ups while moving around the "File list" ??
Richard S.
Since no one had bothered to comment I'll post a screen capture of my desktop to illustrate the problem.
Does Piriform have plans to investigate or correct this display bug yet??
Richard S.
Same here (Win7 x64) except the dialog just vanishes, no ugly trace left behind :P
What operating system are you using? Same thing happens on windows 7 64-bit with no trace like Aethec.
We'll have a look at this :)
