Product not permitted
get a popup window says
“This product is not permitted for use in your current location” and closes
ccleaner free - installed and worked yesterday - win 11 -
have proton vpn - turning it off has no impact --ccleaner will still not run
what’s the deal - just installed yesterday
win11 - brave browser - proton vpn
if you are located in russia, ccleaner has things set up to where the ccleaner program cannot be used in russia, due to “sanctions.”
located in USA - and as far as I know proton has no nodes in Russia
Try restarting your router from it’s control panel. (Or switch it’s power off for 5 minutes and then back on).
Others have reported that doing that resets their IP and they are then no longer blocked.
Because of a lot of reasons - not going to do that - I’ll just stop using CCleaner and use Privazer - or any nuber of other apps - it just a habit thing that i use ccleaner at all after they went full tilt nagware
