problems with update ccleaner
dear forum
since last week the update v.5.70.7909 (64 bit) for ccleaner no longer works. What is the problem and how do I solve it?
I have been using your program for years and this was the best program for me to remove redundancies from my computer
When I want to install the update, I get the following message:
cannot access the specified device, path, or file.
You may not have the correct access permissions for the item
Is there anyone who can help me to fix this problem
Thanks in advance
with distinguished regards
Johny Vermeire
****email address removed
What anti virus are you using? Is it up to date?
Are you using Windows 10?
Hello
I use the the virus scanner from windows 10 and the virusscanner is up todate (windows defender)
Johny Vermeire
Hi @vermeire johny, thanks for reaching out to our community for help. Our support team can help you with this error - please drop us an email on support@ccleaner.com and we will be in touch soon. Hope this helps! ?
