Hi, I have been having problems with Task Manager XP sp3 not helping me "end a process" and then I eventually have to power off my notebook. It used to work fine. I would click on the Process and end task and if that failed then I would do Ctrl + Alt + Del and click on task manager in the task bar and that would end the process.
I would appreciate any and all suggestions.
Thank you for your time.
