Just to let you know, in both 1.40 and 1.41 there is a bug for Symantec Antivirus Corp Ed-v 10.1.5.5000. When you run the Scan for Issues, it shows there are 4 install files that should be deleted. These 4 files have never shown up before. So I went ahead and cleaned them. But when you run the scan a second time, they show up again. They never really go away. I am running Windows Vista. Everything was fine up until 1.40, so I keep using 1.39.
Have you tried right clicking CCleaner and selecting 'Run as administrator', then clean the issues?
I just tried it and it worked fine, I guess. If I run it the normal way, the 4 files come up that you can never get rid of, but when you run it as Administrator, they never show up to begin with, which is how it had always run before using 1.40 or 1.41. Not sure why I have to do that, but at least it works now, THANKS.
