problems with my ms outlook 2003
When I cleaned register I can't no more activate a link in a opened e-mail message. This was already done with c cleaner free same version, some versions previously there were never problems.
c cleaner pro v 5.32.6129 64bit
ms outlook 2003 v 6.1.7601 sp1 build7601
win. 7 home premium 64 bit sp1
try restoring your registry from the backup CC made before you cleaned it. (providing you did the backup of course)
if you didn't, go back to a previous system Restore Point.
I do that regularly, but the registry is not cleaned in that case.
What has changed in cc because there were never problems before ?
what do you "I do that regularly", use the reg cleaner, restore the registry from the .reg backup, or use Restore Points to fix problems caused by cleaning the registry?
if your links in email messages aren't working, try this.
admittedly it's a bit old now; http://www.urtech.ca/2012/03/solved-outlook-links-result-in-this-operation-has-been-cancelled-die-to-restrictions/
I mean that I regularly clean the registry, that's all. Sorry for the bad explanation, I'm not good at the English language.
Meanwhile I use a webmail with the same email name.
Thanks for the possible solution to the problem, I will try it tomorrow now and let it now.
Hi, it's fixed and working well. I thank you very much for your help. Regards. :)
no worries, thanks for posting back.
