Please list the following when making a post here:
- Operating System (+ Service Pack #) that you have a problem with
- Problem(s) you are having, or have had
- Solution(s) to the problem(s) along with a link to the solutions if the solution is a download.
If you just have a problem, list the problem so others can post solutions.
This is a place for real people with real problems.
Thank you!
___________________
Windows 7 Solutions
___________________
- Start Menu -> Classic Shell -> http://classicshell.sourceforge.net/ -> Fixes start menu search behavior/run box behavior/makes menus more direct
- Windows Explorer Navigation -> Right-click My Computer/Properties/Tools/Folder Options/Select Auto Expand folders -> Fixes having to manually tree out menus
- Muddy sound in WMP -> Open Media Player/CTRL + 3/Right-Click a blank part of WMP/Enhancements/Graphic Equalizer. Be sure you click the individual slider option so they won't all follow your mouse. Be sure the EQ is ON & drag the last slider on the right all the way up. Drag the next to the last slider to halfway between 50% & 100% (around 75%). The treble boost will greatly enhance your music listening with a clarity you may have been missing all along.
- No treble/bass controls -> I got a rockfish card with creative chipset -> Visit a local http://www.bestbuy.com/ location -> Drivers included with the card allow you to change treble/bass & it works systemwide.
- Cannot edit photos with Windows Image Viewer -> http://explore.live.com/windows-live-essentials?os=other & choose photo gallery -> feature was shipped with Vista, & this is supposed to add it back
- Make Windows Explorer tree desktop folders out -> Skip the "Favorites" location & navigate using Desktop under user name (below home group) instead.
- Image Viewer fix (Windows 7 viewer pixelates low res images when enlarged, & doesn't display GIF images in the viewer... Users have to use Internet browser to view animated Gif files, which is very inconvenient! Windows XP would smooth pictures instead of pixelating them, & view animated GIF files too!) http://sites.google.com/site/neotechni/Home/programs & scroll down to picture2.zip. Works in 7 & is a clone of XP image viewer. Can view GIF files as well. You will need to download mscomctl.ocx from somewhere such as http://www.ocxdump.com/download-ocx-files_new.php/ocxfiles/M/MSCOMCTL.OCX/6.01.9782/download.html & place it in the same directory as the viewer file.
____________________
Windows XP Solutions
- Ugly cartoony appearance -> http://www.softpedia.com/get/Desktop-Enhancements/Themes/Royale-Theme-for-WinXP.shtml This visual style for XP really makes it look sooo much better!
___________________________
Windows 7 unsolved problems
- Cannot drag a shortcut from the top left of a title bar to another location. XP would do this. -> Anyone know how a good way to fix this?
- Right click on desktop/personalize/display. Click Adjust Resolution, then click back, & click Change Display Settings. They are exactly the same. -> Anyone know how to remove the duplicate entry? Maybe some registry hack or something? You can check the address bar & clearly see that not only are the screens exactly the same, they are the exact same address. Very annoying to have duplicity!
- In XP, it's easy to navigate to the content.ie5 folder using internet explorer to dig in the cache & find what your looking. It's next to impossible in 7, unless you go manually to that folder!
