CC works great. BUT how do I stop CC from deleting my Quicken
information? I can't seem to find it on the list to deselect. Please
be gentle with your answer as I am a novice.....
I don't use quicken but I'm sure I can help you find your problem. Do you know where you are saving you quicken files too?
Ok let's see if I give you the right answer....
C:\Documents & Settings\user\My Documents\Business\Quicken\Backup\Backup/QDAta1.qdf
Is this what you need?
Thank you.
