Hello, I recently used Recuva to rescue an .rtf file that was said to be in an excellent state. However, when I opened it I got encoding like
`1às+5¢ ñ ðl ¨ñ³Ìpr(Ñ1÷!ˆ°À1ÐF’òpFó€Hs ŽÁ0àñ0ñØ&"„ðòðñ s^p
Recuva will just copy whatever data is in the clusters allocated (or formally allocated) to that file, whatever that data is. A state of Excellent means that at this time the clusters are not overwritten by any other live file. Some or all of the clusters could have been overwritten by a file which has subsequently been deleted.
If Word or Notepad won't open the file then it is probably beyond saving. You could run a deep scan to see if there are any copies of this file but the odds are not in your favour..
My memory may be wrong,
BUT what I remember from when I used XP was that NotePad could not use RTF files, I but WordPad could.
It's not that it can't open in Microsoft Word and Notepad, it's just that it still displays the same encoding language.
