problem with lang-1043.dll during the CCleaner setup
hello all :)
i just try to update CCleaner to the last version on my windows Vista 64bit system but when i push the button to install CCleaner it stop{hang} during the install i see that it stops/hang to the point where i can see {lang-1043.dll}the setup does not go further then this to finishing the setup of CCleaner and i did un-install the previous version before i do the setup of the newer version also i did download CCleaner twice from the website to be sure that i downloaded CCleaner correctly so can you please help me with this to solve this issue so that i can setup CCleaner without any :( problems :(
hello all :)
Hello amsjinjoe,
Is C:\Program Files\CCleaner gone after the uninstall.Try clicking on the UNINST.EXE in that folder.
Then try installing again.
What language is 1043?
:) davey
P.S. If that doesn't work,you can try the Portable version Here. http://www.CCleaner.com/download/builds
