Problem with Google Chrome
There's a problem with the cleaning of Chrome's cache. Every time I do the cleaning, it erases every new bookmark added
Some others have already reported this as well
http://forum.piriform.com/index.php?showtopic=18038
I can't replicate this issue on two machines here, can you provide more info please.
My OS is Windows Vista sp1.
The cleaning does not erase all my bookmarks: only the those added after the installation of the latest CCleaner version. And every time I add a new bookmark and then perform the cleaning, I lost it.
The attachment is the log of the last cleaning.
log.txt
Just a thought, Mr.G,
immanuel1789 seems to be italian, and seems that CCleaner looks for the Chrome files in %localappdata%.
Perhaps the issue could affect some non-english localized Windows versions? (this could explain why it
doesn't surface on your test machines)
I wrote some messages on the forum about the different Environment Variables, sometime ago:
Forum Link
Note: On my Windows XP SP3 (italian localized) typing %localappdata% in Start>Run can't open any folder (file not found)
Note2: Actually don't have Google Chrome installed (hating it :P ), but if you think this could
be of any help, i will install, just for test purposes. :)
I'm having the same problem, and I'm in the US. On XP SP3. Also, several websites are not showing up correctly in Chrome since I downloaded the latest version of CCleaner.
